New release probs???
It looks like 2.9rc6 seems to have a problem when activating the firewall, I tried to masquerade traffic between 2 ip’s and it just didnt want to work. I have been haveing this wierd issue for the last day or so. Has anyone else had the same problem??
2.9 is a rather impressive os so I am looking forward to using it some more…
I’m using rc5/6 with no problems in masq that I know of. Post your relevant config entries if you wish to have more help.
Sam
You should use chain=srcnat.
One I set other chain name, and after it I have problems with nat traffic.
The evening I installed 2.9rc6 It work alright but was abit unstable.
chain=srcnat out-interface=toserver src-address=192.168.4.0/24 action=masquerade
This worked on 2.8 it worked lastnight and now it dont wanna work no more???
Do you think a reboot of the box will help, or maybe a system reset??
