(from this point I get a DHCP wan address from the ISP)
changed interface list WAN definition from ether1 to INTERNET
add comment=defconf name=WAN
add comment=defconf interface=INTERNET list=WAN
I can ping 8.8.8.8 from the router ping tool out the WAN, but I get no internet access from the WLAN/LAN ports (can ping router obviously).
a) The nat masquerade and default firewall rules seem to use the “WAN” definition above but I have tried changing them directly to use “INTERNET” without any luck.
But I would recommend putting a managed switch in front of the router to handle the 10VLAN tagging for you.
Noticed a significant slowdown when I ran into a Google fiber install that needed VLAN2 on the WAN port. If I had an RB260GS handy… I bet it would have cured all.
I have a 1Gb connection/plan. Ah ok, are you saying these routers might have issues with throughput when vlanning a 1Gb wan link? I would have to do speed tests with both routers to compare - it does seem a little down from previous but the last test was several moths ago.
Interesting idea that though, but prefer not to add another piece of hardware and power pack to the mix. Thanks
