New Router
Just got a new router with 6.7 in it. I got 5.26 on my aps and ptps, etc. Do I need to put 6.7 on everything? Could this cause me trouble if I do not?
On live network that is a working OK using V5.26?
It would in my opinion be a very big gamble, It could work out great or be a total disaster.
I always test on a separate section of my network first with any updates or fixes and if happy slowly roll them out to entire network
+1… there is no problem having different versions on different things. Unless you need something in the new versions I wouldn’t roll it out to the rest of the stuff until you full test it.
Thanks for the comments. I will start installing 6.7 on some of the less loaded sites and see how it goes. Again thanks! :smiley:
