New sectors
I had N & S sectors and I just added E & W. N is on 20 MHz, S is on 10 MHz. I was trying to determine which sector was which (of E & W) by how much signal I had from 200’ to the west where I currently connect to S with a -60ish signal. I can’t see E or W from the CPE. I can connect to either E or W and see both other 20 MHz sectors equally well (40s from one, 50s from the other). I have 4x SR5 cards in a modified (by MT) RB14. The two old sectors have u.FL pigtails while the new ones have MMCX. Ideas?
[admin@ICSAP1-HammettFarms1] > /interface wireless print
 0  R name="North" mtu=1500 mac-address=00:15:6D:10:0A:F9 arp=proxy-arp disable-running-check=no interface-type=Atheros AR5213 radio-name="00156D100AF9"
      mode=ap-bridge ssid="ICS1" area="" frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5785 band=5ghz scan-list=default
      rate-set=default supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps max-station-count=2007
      ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=enabled periodic-calibration-interval=60
      burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
      wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      proprietary-extensions=pre-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=short
      compression=yes allow-sharedkey=no
 1  R name="South" mtu=1500 mac-address=00:15:6D:10:0A:FA arp=enabled disable-running-check=no interface-type=Atheros AR5213 radio-name="00156D100AFA"
      mode=ap-bridge ssid="ICS2" area="" frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5810 band=5ghz-10mhz scan-list=5810
      ack-timeout=121 tx-power-mode=default noise-floor-threshold=default periodic-calibration=enabled periodic-calibration-interval=60 burst-time=disabled
      dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
      compression=no allow-sharedkey=no
 2    name="wlan1" mtu=1500 mac-address=00:15:6D:50:16:C6 arp=enabled disable-running-check=no interface-type=Atheros AR5213 radio-name="00156D5016C6"
      mode=ap-bridge ssid="ICS3" area="" frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5745 band=5ghz scan-list=default
      proprietary-extensions=pre-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
 3    name="wlan2" mtu=1500 mac-address=00:15:6D:50:17:09 arp=enabled disable-running-check=no interface-type=Atheros AR5213 radio-name="00156D501709"
      mode=ap-bridge ssid="ICS4" area="" frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5765 band=5ghz scan-list=default
Solved…
Antenna A vs. Antenna B.
Beers to Brad Belton and Cameron next time I see them.
