New set dual polarity antenna doubts. Please suggest.
I just ordered a new set of dual polarity antennas for a new BTS we are setting;
My setup goes like this:
AP Side >>> Mini PCI F50 Pro + 17 dbi Sector (Single polarity)
Client Side >>> Mini PCI Compex + 30 dbi Grid
Singal was -56/58
New setup goes like this:
AP Side >>> R52Hn + 16dbi Sector (Dual Polarity) As per the vendor tells me
New signal level - 85/90
What has gone wrong please suggest?
I suspect the dual polarity sector. May be it is not 16 dbi but just 8/10 dbi.
Check that you are using both chains for tx as well as both for rx.
YES. I have chain 0 and chain 1 both tx and rx ticked.
Try to verify the sector antenna data.
As a rule of thumb a dual pol antenna needs double size
for the same gain. May be you’re at the edge of the
sector? You loose 3db spreading power to 2 polarities.
The client what i am talking about was connected initially with a Grid as it was the only client.
Then we had more clients so we got a single polarity sector to replace the grid.
Then we had a few clients where we had the SXT’s and 711-5hn hence inorder to use the “n” we order the dual pol and moreover we r running the dual pol successfully on another base.
All other clients may be on edges but this one we r testing on is very str8 in line with the sector.
I don’t think that since the client end is not “n” it should affect. Neways I have not yet put it on 5Ghz A/N. Because if I use that everything goes off completely. So it is only 5Ghz A so far
