(new) SXT LTE kit availability
Just a short and quick question, is there any timeline for the release of the new SXT LTE Kit as some other products from the MUM are already listed ? I am desperately in need of a better solution, currently i have a wap lte kit at a location, which barely has enough reception. the only available band is 20, so the old sxt lte would not work.
thanks
Nobody can promise anything. The only answer you’ll get is “It is closer than ever before!” Don’t try to hold your breath. Of course MikroTik is doing their best, it will bring revenue for them.
If you are in a hurry you should try wAP LTE Kit. You can install pigtails and fit a more directional external antenna if necessary to your wAP LTE Kit.
[Edit: Realized you already have a wAP LTE Kit]
