Looking for advice on some new equipment and what not.
It is a small business setting. 100 user base. 10 servers. None are extremely high demanding.
Does Mikrotik have a high end firewall equivalent? Or would you suggest something like a Sonicwall - prior to the back bone?
Right now we are using low end consumer grade hardware - ie OLD Dlink hardware. Im ashamed.
Its ppop -
Modem - switch - 2 routers - 1 for main connection, one for a dedicated office connection - various switches and other backbone equipment.
What mikrotik would you recommend for this as well? RB750GL / HnD? Or RB2011LS-IN / wifi version?
What are the differences between the 2 models - older and newer? New features? Other than the lcd screen, additional ports and so on?
