So I need help setting up a Mikrotik CSR309-1G-8S+IN, i went thru the guides and setup dhcp, dns, both wan ip and lan ip but I’m not getting internet connection. I didnt do firewall or wlan, not sure if i need firewall or wlan setup tho. Below is the equipment Im using
1 Mikrotik crs309
2 hard wire mesh deco x75 Pro wired to port 2 and 3
Dynamic Wan service on port 1
do i need to setup wlan or firewall? i do need port forwarding
is there a guide for the setup im using that will help setup up my wlan
what could be causing the lack of internet? firewall not setup maybe? do I need the firewall?
