pls i need help on how to download the user manager. if you can give me the direct link for the download. if the help manual too can be addedd i will be most grateful.pls i need it urgently. thanks
http://www.mikrotik.com/download.html
Select Your System and download the Package from the List <.npk File>
Login in to the router Thru FTP, Copy the file in to router and Reboot it.
After reeboot u will find the same under /tool menu
/tool user-manager
Dear Ashish ;
Glad to write to you .
I checked my MT OS i didn’t find user-manager inside tool menu .
could you explain how it will helps ? .
with best regards .
using RB or PC..??
Hi Ashish ;
Glad to hear from you .
i am using pc .
i wrote to you in another article you mentioned your MSN id in to get permission from you to add your id to my list .
will be waiting your reply eagerly .
with best regards .
