new type of Load Balancing
can anyone help me!
i am using 2 wans one is of 2mb and another is 8 mb.
i want to make load balancing and also want to use maximum internet from 8mb.
pcc is not a good method for UnEqual wan links so i used to prefer any other method here,
but the problem is that i want to use maximum internet from my wan 2 (8mb).
if any exert will help me it will be gratefull for me!
thanks in advance
Per packet balancing is not possible in such scenarios. Best option is PCC.
i do not want to balance any packet, the purpose of my query is just to make smooth internet connection. is there any way to standby a link (when primary link goes down the standby link step into primary wan’s shoe)
you can create PCC that divide connections into 5 groups and send 4 groups to one gateway and 1 to another.
But traffic wise this will happen only if all your connections are equal.
per packet load balancing can only happen if packets will be leaving both getaways with the same source address.
