New user needs mesh setup advice
Greetings Mikrotik users.
I have been asked to help configure 8 RB433 systems for a local school to provide wireless across their campus. When I came onsite the systems were each setup as with their own SSID and keys, resulting in poor coverage in many areas as users jumped from ap to ap.
I located the Mesh WDS guide on the wiki and configured the devices as shown here
http://wiki.mikrotik.com/wiki/Mesh_wds , this seems to be working right now, but it appears that the wireless devices are sharing their data over the wireless , cutting into available bandwidth and creating unneeded wireless traffic. This mesh setup is exactly what I am after from the wireless clients perspective, but I am worried that once school starts the wireless will be saturated.
Can I make the mesh devices communicate with each other over the wired LAN instead? Is there a better setup I should be using ? Any help or advice would be greatly appreciated.
Tailspin
I assume each 433 has got just one miniPCI card, hence the limited options.
If yes, i am not aware that you have an option besides wds.
With wds you can use a bridged setup like i’m sure you did or a routed setup which would require setting up virtual APs - more tedious to setup but i think more reliable than wds bridging.
On the side, if you really anticipate heavy traffic on each ap then it would probably be worth the extra bucks getting a second card for each router and setting up true repeaters.
Regards.
Each device only has one wireless card, but has 3 ethernet ports, of which only one is in use, providing power and LAN access to each RB433.
WDS appears to do what I want from the students perspective, They see only 1 wireless network no matter where they are on the campus and can move around between coverage areas without a problem.
My concern is the back end, If I am reading correctly WDS is using up to half the wireless bandwidth for the RB433s to communicate with each other, and the wired network is only being used by 1 of the RB433’s which is acting as a gateway for the rest ? ( How do I tell which one?)
I would prefer if the wireless was only used for Students connections, and all network traffic to the internet, lan, or other RB’s then occured over the wired LAN.
Tailspin
Even with the WDS, you should be able to create virtual AP’s, keep the WDS SSID hidden and broadcast virtual AP with each VAP on its own subnet.
I know you can have a virtual AP running WDS while the real AP is not, dunno if it will work as a straight WDS bridge/repeater tho.
