For
Preshared key: Set this key for WPA/WPA2 (the same as WPA Pre-Shared Key/WPA2 Pre-Shared Key in Winbox).
Enc key: leave it blank for WPA/WPA2.
Enc algo: select AES-CCM or TKIP (AES is more recommended);
Thanks!! and sorry to put this message in wrong site..
Two last question..
Wireless clients should be Mikrotik? I try with laptop and log: got RADIUS accept for XX:XX:XX:XX:XX:XX on wlan1, but failed to validate encryption key.
I follow the steps in manual but if I don’t active WEP or WPA in wireless security profiles, then the comunication is not encrypted.
If in security profiles leave Mode: none (encryption) then RADIUS users can connect via wireless!!
But if I set Mode: dinamyc keys then users cannot connect..
I need RADIUS wireless users connection ecnrypted.
Use mode=dynamic-keys
Configure WPA/WPA2 PSK on client laptop.
Ok… but what is the function of wireless parameter in usermanager v5? wireless key?
If I configure security profile with dynamic keys wpa psk then I put a unique key.. I don’t understand what is the function of parameters (wireless encryption) in usermanager v5
For
I don’t understand the function of parameters “preshared key” and “Enc algo”. I set this parameters to user and nothing happen.. The problem is I don’t understand how to use this paramaters.
Sorry
I set a user with a MAC? or I set user with username and password?? This parameters work with hotspot?
Can I configure user demo with this parameters and the connection will be encrypted??
Or not work with hotspot? Only work with wireless? (no hotspot, no ppp, no login)
If work with wireless I need to configure user with MAC address??
I test all this functionalities and any work! I don’t say this system not work! Only say that I don’t undestand how it work and only I need a help..
your questions indicate that your understanding of networking and RouterOS in general is very low, I advise you to take some mikrotik training course, or watch online tutorials;
