I am getting frustrated with the new Routerboards
LHG-HP5
and the SXT series
i can set them up with mac address put in an IP address but they do not show up on winbox under neighbours
only started having this problem with the new devices .
Has something changed that i am not aware of ?
What RouterOS versions do you use?
Is your PC’s IP fixed, or do you get it from a DHCP server? Is the server on Mikrotik?
And of course, you cannot see in neighbours yourself.
i solved it by deleting the default configuration
and doing it manually .
I guess quickset does not work any more
