new x86 server. HDD vs CF vs USB Flash.
Hi
I plan to switch from RB750G to a x86 machine (Dell Poweredge 2850)
On what media do you recommend to put the Level5 licence ?
The system will be used for hotspot/usermanager, webproxy on local scsi hdd (if mikrotik sees dell perc5 raid controller)
My options are:
  • hdd (2 x 36gb scsi)
  • usb (some Kingston/Kingmax/Verbatim/other 4/8gb)
  • Compact Flash Verbatim 4Gb + IDE Adapter.
Prices are the same for the last two and I understand that the memory technology is the same.
What whould you recommend ?
do not use usb for the OS in later versions of routeros - the disk will keep getting ejected and then your admin password will be reset to blank and changes wont be saved. there is a problem with hotplug storage for some reason it seems.
i’ve decided to go on a Kingston CF 4gb.
Hope it will last at least a year :slight_smile:
just bought the server…
RouterOS netinstall won’t see the scsi drives (No harddrives found)
Controller is LSI Dell Perc 4
Any suggestions ? (i’ve talked with the hardware supplier and try every server they have until I’ll find one that works)
thank you
