newbea questions for RB5xx
as the topic implies newbea question! i ve some experience with routeros and rb133c all for connecting to APs as client; now i want to take a step further im planning to use rb532 with two radios; one r52 with grid antenna to connect the base and one xr2 or senao 8602 for omni directional to repat the signal ; now i need some help to improve this;
Regards
what you mean by - improve this?
what is wrong, something is not working?
Try using routing - if you’re not already, you did not say. if using 2.4GHz only use channels 1,6 or 11 and I have had good success with the 8602
solved; i meant achieving; done this by routing thankx for the help; newbie on the run :laughing:
