Newbie: 4 wan links
Thank you for reading and special thank you on any input that you can give.
I have 3 RV042 dual van rooter’s, to be able to route 4 adsl links for 120 users.
it works ok but puts a delay of s second on dns resolving.
I want to change this setup and want to use mikrotik router to do the balancing.
By reading the wiki and the documentation that i could find i am very interested to use
Standard Policy-Based Routing with Failover
Equal bandwidth sharing among users
P2P limit
Before i get in to it and drive myself crazy is there something that anyone can suggest or help with example.
any input will be very much appreciated
Regards
I suggest you can install the demo router,
and try examples in WIKI.
If you have problem, read the manual… and then you can ask again in this forum.
