Hi Folks,
So, I understand that this is not “active” PoE, but rather “passive”
which (should) allow me to power the board itself through PoE.
Purchased the Cable Matters Inline Passive Power Injector over Ethernet
cable set (essentially 2, Y shaped cables, I can diagram if helpful but
pretty straight forward)
Needless to say, this isn’t working. Have mucked with terminal, going
so far as “/interface ethernet poe settings print” which generates
“bad command name poe” , as I suspect the PoE commands are
for boards with active PoE.
SO, my question is how can I configure this board to power up over PoE?
The ones on Amazon pass power as in the bottom diagram on the product page. Power is not coming out the RJ45 data connection.
Just get the MT one: https://mikrotik.com/product/RBGPOE or equivalent.
The device you have does not actually provide POE power, as the other poster noted. You need to plug the router into a POE switch that supports passive 24V POE, or you need to buy a passive 24V POE injector. I power my RB750gr3 from a Unifi POE switch. This injector should work too:
