Mikrotik docs on CRS series is a terable
Maybe my config help to you little.
/interface ethernet switch
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports="SFP-10G,ether1-QRT2,ether2,ether3,ether4,ether5,ether6-34410A,ether7-MyPC,ether8-MyPC,ether9,ether10-Akip,ether11,ether12,ether13,ether14-R7000,ether15,ether16,ether17,ether18-sosedi146,ether19,ether20,ether21-MaxiSRV,ether22,ether23-MySRV,ether24-MySRV,sfp-sfpplus1,switch1-cpu"
Drop all packet who not in VLAN on all ports.
/interface ethernet switch trunk
add member-ports=ether7-MyPC,ether8-MyPC name=MyPC-trunk
add member-ports=ether24-MySRV,ether23-MySRV name=MySRV-trunk
Add ports to SLA (Static Link Aggregation)
/interface ethernet switch egress-vlan-tag
add tagged-ports=SFP-10G vlan-id=3
add tagged-ports=ether1-QRT2,SFP-10G vlan-id=2
Accept tagged packets VLAN 3 from SFP-10G port
Accept tagged packets VLAN 2 from ether1-QRT2 and SFP-10G port
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=3 ports=ether21-MaxiSRV sa-learning=yes
add customer-vid=0 new-customer-vid=2 ports=ether18-sosedi146 sa-learning=yes
Convert untagged packets from ether21-MaxiSRV port to tagged VLAN 3
Convert untagged packets from ether18-sosedi146 port to tagged VLAN 2
set 0 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=100 learn-override=yes
set 1 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 2 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 3 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 4 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 5 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 6 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 7 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 8 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 9 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 10 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 11 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 12 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 13 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=50 learn-override=yes
set 14 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 15 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 16 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 17 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 18 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 19 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 20 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 21 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=10 learn-override=yes
set 22 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=100 learn-override=yes
set 23 action-on-static-station-move=drop drop-dynamic-mac-move=yes dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=100 learn-override=yes
set 24 dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=100 learn-override=yes
set 25 dscp-based-qos-dscp-to-dscp-mapping=no isolation-leakage-profile-override=0 learn-limit=1023 learn-override=yes
set 26 dscp-based-qos-dscp-to-dscp-mapping=no learn-limit=1023 learn-override=yes
Add internal loop protect on ports and add limits to adding MACs to switch table for protect MAC flood attack.
add ports=ether21-MaxiSRV,SFP-10G vlan-id=3
add ports=MyPC-trunk,MySRV-trunk,switch1-cpu,ether1-QRT2,ether6-34410A,ether10-Akip,ether14-R7000,SFP-10G vlan-id=0
add ports=MySRV-trunk,SFP-10G vlan-id=4
add ports=ether1-QRT2,ether18-sosedi146,SFP-10G vlan-id=2
Accept VLANS on ports.
I delete some parts, because it is not a basic.
When you been configured it, prepare serial console cable! at first time it is must have while you understand what you need append CPU and you PC ports must be in one VLAN.
I do not know, why mikrotik not place it in the package…
