newbie default route question
Hi All
I’m having a problem setting a default route between 2 RB450G devices.
I have one router(A) connected to the internet. Another router(B) also connects to this router(A).
At router(B) I am unable to set a default route to a specific IP address on routerA. All I can do is set the routes interface. What am I doing wrong?
Some detail -
RouterA
Internet Port (eth4) - 192.168.0.254/24
Router(B) Port (eth5) - 10.1.0.1/24 - connects to routerB eth1
RouterB
RouterA Port (eth1) 10.2.0.1/24 - connects to routerA eth5
I can create a static default route on RouterA to my DSL modem and RouterOs shows..
DAS 0.0.0.0/0 gateway 192.168.0.1 reachable eth4-temp-internet
and all is well on routerA.
On routerB I try to create a similar default route to routerA but routerOs shows…
A 0.0.0.0/0 gateway 10.1.0.1 unreachable
I have added a static route to 10.1.0.0/24 using interface eth1.
How do I get a default route setup on routerB to point to routerA.
/ip route add dst-address=0.0.0.0/0 gateway=10.1.0.1 distance=1
that should do the trick. Also make sure to check the firewall on router A if you have entered any rules.
Edit: Can you ping and telnet from RouterB to RouterA (that is, do you have full access)?
You would have thought that this would do the job, but the default gateway from routerB to routerA remains unreachable! I can ping the interface 10.1.0.1 on routerA from routerB and I can ping 10.2.0.1 on routerB from routerA.
I needed to encrypt this link so what I did was setup IPSEC security between 10.1.0.1 and 10.2.0.1. Then an EOIP tunnel on this ‘link’ , created addresses on each router in the same subnet and then added a default gateway over the EOIP tunnel.
I still cant understand why I was not able to create a default route from routerB from routerA? Can some clever soul explain it in words not exceeding 2 syllables please?
You kind of forgot to mention the tunnel :slight_smile: Anyway, I’d suggest that you try to telnet from RouterA to RouterB to make sure that normal IP traffic can traverse the link without any problems.
Marcus
Sorry I didn’t mention the tunnel as I thought that I could build the tunnel after getting the routers to talk to each other.
The routers ping each other without problems.
If I connect a client(PC) to routerA(10.1.0.1) I cannot ping/telnet/etc anything on/via routerB(10.2.0.1).
If I connect a client(PC) to routerB(10.2.0.1) I cannot ping/telnet/etc anything on/via routerA(10.1.0.1).
This has to be telling me something but I don’t know what :frowning: As the routers will talk to each other via ICMP(ping) is my problem with firewall rules?
I believe you have some issues with your firewall in that case. For some reason your routers does not forward traffic to the next interface (that is towards next router).
