Newbie Firewall help.
Why is the rule:
add action=drop chain=forward connection-state=new connection-type="" \
    dst-address=192.168.10.140 in-interface=ether2 log=yes out-interface=\
    ether1
Not stopping an SSH connection from 192.168.86.2 (ether2) to 192.168.10.140 (ether1)?
If I disable the forward all rule:
add action=accept chain=forward connection-state=new in-interface=ether2 \
    out-interface=ether1
It stops connecting along with everything else.
Complete ruleset:
    established,related,untracked disabled=yes
add action=drop chain=input comment="Drop Invalid" connection-state=invalid
    ether1
add action=accept chain=input comment="Winbox accept" dst-port=8291 \
    in-interface=ether1 protocol=tcp src-address=192.168.10.10-192.168.10.254
add action=accept chain=input connection-state=new dst-port=8291 \
    in-interface=ether2 protocol=tcp src-address=192.168.86.2
add action=drop chain=input comment="Drop all NOT coming from Ether1" \
    disabled=yes in-interface=!ether1
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
add action=accept chain=forward comment="RDP (Any)  to 192.168.86.2" \
    connection-state=new dst-address=192.168.86.2 in-interface=ether1 \
    out-interface=ether2 protocol=tcp
add action=drop chain=forward comment="Drop New" connection-state=new
    ipsec-policy=out,none out-interface=ether1
Thanks in advance :slight_smile:
I was doing all the config in Winbox. When I posted here I noticed the connection-type=“” part. Removing that fixed it.
I am kinda surprised that broke the rule. Would love to know why please.
Original rule
    ether1
I’d say because connection-type=“” doesn’t match on any of the possible values of connection-type (new, established, related, untracked, invalid).
Other than that, have a look what stateful firewall means and how it works. Basically all the filter rules should be placed after the initial “accept untracked,established,related” and “drop invalid” ones in each chain, because only connection-state=new packets get past those two rules. So the decision whether to allow or not the whole connection is made once, using those rules handling new packets, and packets belonging to accepted connections are then handled by a single rule (accept established,related,untracked). And you don’t need to match on connection-state=new (which also consumes a small bit of CPU).
It’s connection-type not connection-state.
I’ve misread that (because connection-type is rarely used), but it’s the same case. “” doesn’t match any value of connection-type so the rule as a whole never matches.
Unplug your router from the internet it is in a very unsafe condition.
You have given access to your winbox port to the whole world.
Assuming ether1 is your WAN port…
The source addresses you put in there are no protection.
Only use VPN tunnel to config the router from external locations.
add action=accept chain=input comment=“Winbox accept” dst-port=8291
Thanks Sindy.
Anav, it’s sitting in a private network. Worry not :slight_smile:
phew!!! Happy routing LOL.
