Greets, i’m newbie to mikrotik, and I need to protect my MT router from public “attacks”, eg. no ping,no login to ssh etc… but it should be accessible from local network.
p.s. is there any way to reduce DDOS attacks?
thank you very much.
maybe the following will help:
http://www.mikrotik.com/docs/ros/2.8/howto/howto.content#12.2.1
Edgars
Hi people, we are planing to switch to MT but loadbalancing with failover doesn’t work explained in the posts. We have 2 ISP with real IP’s… problem… netwatch can ping both my gateways from both links.
Any idea how to set BGP with load-balancing and failover in MT?
cheers
Hmm nope just had another thought and the idea I had wont work ![]()
