Newbie Help
I need some help or a link for information to solve a simple issue. As I try to test the performance of my RB411AH with WLM54GP radio. I am running RouterOS 3.22.
My MikroTik Router is behind my LinkSys WRT54G router which is behind my cable modem. I am having difficulty getting data through the wireless to the internet.
Cable Modem <==> WRT54G = 192.168.1.1 <==> RB411AH = 192.168.1.125 <==> bridge = ether1 + wlan1
I can connect to the wlan1 wirelessly but not to the internet. I’m missing something. Any suggestions or direction would be appreciated.
Not sure what the issue is. I can connect to the RB411AH through the WRT54G using WinBox. So the Ethernet port is running and available on the internal side of the network, just not getting out to the rest of the world.
Thanks,
Well, for starters, you can’t have two DHCP servers running. Two many conflicts occur. Once I concluded that both the LinkSys and the RB411AH were both trying to be the DHCP server, it helped.
Problem solved. All is well.
