I will admit to be an idiot when it comes to setting up this type of stuff so please forgive my ignorance. Can someone please explain or point me to a link that will walk me through the client setup of board 133c3? Here’s the scenario - I have a 133c3 board and antenna on a windows machine that i’m trying to get to work with a linksys router. That’s it. If someone could explain in easy steps I would really appreciate it. Thank you!
startup guide:
http://www.routerboard.com/pdf/rb133mA.pdf
software basics:
http://www.mikrotik.com/testdocs/ros/2.9/guide/basic.php
manual, wiki: see forum header
There is a steep learning curve, but the wiki covers lots of topics and is very good. This not your common Linksys router and is much more complicated and powerful. Personally I use winbox for most programming as it is easier for me to use. Some things MUST be programmed via command line and you can do that too from within winbox if you like. Click the “New Terminal” button for command line or telnet into it.
I hope this helps.
You need to be a bit more specific…
Is the RB133 going to be a client for the Wiindows PC (i.e the Linksys is the AP)? or what?
