On my old Fast Ethernet Router I would go into my NAT / Virtual Server Setting and Setup my Security system like below. How can I set it up on the New Router Mikrotik RB750GL?
Thanks for your help.
Here is how to do :
add action=dst-nat chain=dstnat dst-port=9000 in-interface=WAN1 protocol=tcp to-addresses=192.168.10.3 to-ports=9000
add action=dst-nat chain=dstnat dst-port=8000 in-interface=WAN1 protocol=tcp to-addresses=192.168.10.3 to-ports=8000
Just adjust your WAN interface.
Regards,
Like the below?
I get the following errors
in/out-interface matcher not possible when interface (ether3-slave-local) is slave - use master instead (ether2-master-local)
No, your in-terface must be the WAN, not your local-bridge
