Newbie needing help
Hi All,
I’m a complete newbie to networking and would greatly appreciate any support as my Mikrotik isn’t getting Internet from my ISP’s router for some reason that I can’t work out.
My Mikrotik then connects to two other APs (unifi) and my hikvision security cameras. Everything seems to be fine on the LAN and I can see the cameras etc but nothing has access to the internet and even when I connect my laptop (through Wifi and wired) to the Mikrotik it doesn’t get Internet.
Below is the output information that I get from the Mikrotik router. Does anyone spot an error in the settings? Thank you so much in advance for any help!
# jan/02/1970 01:15:04 by RouterOS 6.40.4
# software id = QZPM-TQ8F
# model = RouterBOARD 952Ui-5ac2nD
# serial number = 924C08A58F04
add admin-mac=CC:2D:E0:DA:24:62 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-DA2467 wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-DA2466 \
    wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
Aside from seriously outdated system (but that’s not breaking it), I don’t see anything obviously wrong, it looks like good old default config from 2017. If you look at DHCP client (IP->DHCP Client), what does it say? Does it get any IP address? And you do have ISP’s router connected to ether1, right?
Yup, wont event discuss a config from that vintage.
Best to upgrade to the long term vers 6 firmware 6.47.9 or something and then implement a config.
You can download the export for this one to base your new config on for the most part,
Thank you I’ll update the system.
Under DHCP client there is an IP address in the field and yes I have ISP’s router connected to ether1.
Thank you I’ll update as suggested.
How do you define “doesn’t get Internet”? Regular web browsing doesn’t work, but what if you try to open https://1.1.1.1/, does that work? Or ping to some numeric address (e.g. 1.1.1.1 again)? What about ping from router itself (open Terminal and try “ping 1.1.1.1”)?
All regular browsing returns the error “No Internet” even when I try to open https://1.1.1.1/ When I ping from the terminal it lists the ISP gateway and says in the status “net unreachable”
So it looks like it’s done by ISP’s router for some reason. Does it work with some different router or directly connected PC? Could it be e.g. locked to specific device (its MAC address)?
I haven’t tried a different router I will try that tomorrow. Ive directly connected and still couldn’t get access to the Internet. Maybe this is an issue with the ISP and not the Mikrotik.
Ive updated and here is the new output incase it now shows an error.
# jan/02/1970 00:17:16 by RouterOS 7.7
# model = RB952Ui-5ac2nD
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether2-master
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=20/40mhz-Ce country=no_country_set disabled=no distance=indoors frequency=auto frequency-mode=\
    manual-txpower mode=ap-bridge ssid=MikroTik-DA2467 station-roaming=enabled wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=no_country_set disabled=no distance=indoors frequency=auto \
    frequency-mode=manual-txpower mode=ap-bridge ssid=MikroTik-DA2466 station-roaming=enabled wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=192.168.88.0
/ip dhcp-client
/ip dns static
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
Thank you very much for all the feedback. It is greatly appreciated.
My idea was whether you’re perhaps replacing some ISP-supplied router, it would be possible that ISP allows it but nothing else. Or is it completely new connection that never worked before?
Btw, you lost some rules in “/ip firewall filter”. Those you previously had with chain=input, you want them back.
It’s not a new connection it was working and suddenly stopped last week.
My guess is that it’s something on ISP’s side. So I’d ask them. Or do you have access to some ISP’s device (modem or something) that you can (are able and allowed to) turn off and on again?
Unfortunately, the ISP won’t let me access their device so I’ve scheduled them to come out and check. Thank you very much for all the help.
That setting made my ISP to shut off internet to me, blaming my IP was used for malicious attacks. I had no clue what it did in those days. Is there a good good reason for you?
Well, this allows your router to be used as DNS resolver. Which is something you may want for your devices in LAN, so not wrong. But if accessible from internet, your router would be open resolver, which is not good, because it really can be used for attacking others. But in OP’s case the original config had firewall preventing access from internet (it’s those chain=input rules that should be put back).
