newbie question: deleting file on router...
I’ve looked at the refman3.0.pdf, but can’t find the answer.
My simple question is, on a router, I have several files, of backups and scripts.
If I want to just delete some of these files, how to proceed to do that?
Thank you for any guidelines…
In WinBox, select the file and click the “-” button from the toolbar. Or in the shell, use “/file remove [id]”.
HTH,
Felix
10q or TY or TYVM !!! :wink:
