I’ve just setup the dude for the first time using my ‘testbed’ network. The dude is running in CHR in vmware player on my laptop.
Currently my testbed network consists of a wireless bridge from my latop’s ethernet port to dynadish-1 which is in a bridge with dynadish-2, which finally connects to a non-mikrotik / basic-router which connects to the internet.
The IPs are assigned as follows:
My local ethernet gets its IP from the router (via the transparent bridge) - 192.168.1.247
dynadish-1: eth1: 192.168.88.1/24, bridge1: 192.168.1.205/24, wlan1: 10.0.0.13/24
dynadish-2: eth1: 192.168.88.1/24, bridge1: 10.0.0.11/24, wlan1: NA
CHR dude server: 192.168.1.198 (via dhcp)
router: 192.126.1.1
I left the eth1 ports at the default in case I ever want to locally debug over lan cable when equipment is finally installed
I added an ip in the range of the router to the bridge1 of dynadish-1 so it could access the internet for services like ntp, etc.
I added the 10.0.0.0/24 IPs to to the wlan sides so they could be used to run point to point speed tests.
When I run the dude on my local machine under vmware, it does indeed generate a map of many devices connected to my router (phones, laptops, the dude server itself, etc)…basically everything in the 192.168.1.0/24 subnet.
It does not see dynadish-2 at at all. I assumed it somehow could trace through devices to find what is connected to them.
Could anyone recommend anything I could try to get the dude to discover the devices on my network.
Is it required that I can ping all devices the dude can see?
I’m new to this area of ‘advanced’ networking - so please assume faulty knowledge of any and all networking topics!
