Finally I bought one of this hardware babies, but I’ve got a problem.
I resolder my serial cable, and now I’ve got connections with routerboard throw serial console, but I can’t geto to it from the network.
Without Ip adress from winbox, I see the RB, but it get pingtimeout.
With IP adress, winbox reacts and writes the appropriate IP adrress but again i can’t connect.
I can’t ping the RB. I can’t arping the RB.
From RB i can’t ping PC, but i CAN arping it.
I used setup and “reset” RB conf.
I use CrossOver UTP to connect PC to RB.
Am I missing something?
(The RB is brand new came with preinstalled 2.9.5 with license until 1 jan 2007).
When I start the RB and try to enter from WinBox … sometimes it connects, but when disconnect, and try to connect again … timed out.
I give different IPs to different port … and nothing. I can’t ping from RB, I can only arping.
Interfaces were enabled by default. I disable-enable all of them but, nothing happens.
I don’t insert gateway, cause I don’t need this device in the network.
