I have only just discovered “The dude” and I like it a lot.
I am just running a home network and have some questions.
So basically I have 3 windows PC’s and a Print Server plus a wireless router on on 192.168.1.x.
On PC is running “The Dude” server.
I have added my the router true ISP IP address manually, same for the first machine at the ISP. i.e. ISP gateway. Trouble is that if I have to restart my router it gets a new IP address and the ISP gateway also probably changes. Is there anyway I can get the thing setup automatically via discovery. The router supports snmp does this help at all?
Also adding the true IP address as a second address on the router 192.168.1.1 does not seem to have any effect, is this correct.
I have only tried version 2.2 would the beta make any difference?
Have added pdf file of network
Local.pdf (243 KB)
