So im new to mikrotik.. but ive been kind of obsessing and spending all my free time trying to understand and improve.. what I was trying to practice here on a small hex.. because im providing internet to just one office for an event so I figured this would be a good exercise.. Should only have about 20 or so devices.. maybe 40 and I doubt it,. im including watches and phones.. Now I wanted to try doing recursive routes and with failover - (Internet connections will be a starlink and a mikrotik lte dish. LTE really only ever gets like 40 megs) but I was going to have the LTE as a failover.. Now in the exercise in the office it seem to work pretty good but im wondering if the Fasttrack being enabled will be a problem.. (Ive starred at that packet flow diagram and im still pretty much learning as Im practicing… sorry I just learn that way.. ) I had a mangle rule there to just try it and it seems to work as well but I dont know if I should continue to use it if I have fast track enabled. Im posting below just to see if anyone can point out if im doing this right or really wrong..
[admin@HEX-Event] > export
# jan/26/2023 21:30:52 by RouterOS 7.7
# software id = E15E-ZB1M
# model = RB760iGS
# serial number =
add admin-mac==auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1_Wan1
set [ find default-name=ether2 ] name=ether2_Wan2
/interface wireguard
/interface vlan
add interface=bridge name=30Production vlan-id=30
add interface=bridge name=200Management vlan-id=200
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=TrustedLAN
/interface lte apn
add interface=ether1_Wan1 name=server1
/ip hotspot profile
add name=30Production ranges=10.30.0.10-10.30.3.250
add name=bridge ranges=192.168.81.10-192.168.81.250
add address-pool=30Production interface=30Production lease-time=8h name=30Production
add address-pool=bridge interface=bridge lease-time=8h name=Bridge81
/port
set 0 name=serial0
/routing table
add disabled=no fib name=WAN21
/snmp community
add addresses=::/0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1
set generic-timeout=5m tcp-established-timeout=8h udp-stream-timeout=1m
set discover-interface-list=all
/ipv6 settings
add comment=defconf interface=ether1_Wan1 list=WAN
add interface=wireguard1 list=TrustedLAN
add interface=bridge list=TrustedLAN
add interface=miamievent list=TrustedLAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add address=192.168.81.1/24 comment=defconf interface=bridge network=192.168.81.0
add address=10.30.0.1/22 interface=30Production network=10.30.0.0
add address=192.168.200.5/24 interface=200Management network=192.168.200.0
/ip dhcp-client
add add-default-route=no comment=defconf interface=ether1_Wan1
add add-default-route=no interface=ether2_Wan2
add address=10.30.0.0/22 dns-server=8.8.8.8,1.1.1.1 gateway=10.30.0.1
add address=192.168.81.0/24 dns-server=192.168.81.1,8.8.8.8 gateway=192.168.81.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
/ip firewall address-list
add address=192.168.0.0/16 list=PrivateIPs
add address=172.16.0.0/12 list=PrivateIPs
add address=10.0.0.0/8 list=PrivateIPs
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!TrustedLAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes dst-address-list=!PrivateIPs new-routing-mark=WAN21 passthrough=yes src-address=192.168.81.249
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether1_Wan1
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether2_Wan2
add disabled=no dst-address=4.2.2.2/32 gateway=10.10.10.1 routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=4.2.2.2 pref-src="" routing-table=main scope=11 suppress-hw-offload=no target-scope=11
add disabled=no dst-address=9.9.9.9/32 gateway=192.168.31.1 routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=9.9.9.9 pref-src="" routing-table=main scope=11 suppress-hw-offload=no target-scope=11
/snmp
/system clock
set time-zone-name=America/New_York
/system identity
set name=HEX-Event
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.windows.com
/system scheduler
/tool mac-server mac-winbox
/tool romon
set enabled=yes
[admin@HEX-Event] >
