I’ve setup a pptp connection to my office VPN I can connect just fine, I created a routing rule like this:
[admin@MikroTik] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.0.1 1
1 S 0.0.0.0/0 192.168.169.1 1
8 A S 0.0.0.0/0 192.168.0.1 1
9 S 0.0.0.0/0 192.168.169.1 2
10 A S 10.10.10.0/24 pptp-out1 1
11 ADC 10.10.10.200/32 10.10.10.206 pptp-out1 0
12 ADC 192.168.0.0/24 192.168.0.254 ETB 0
13 ADC 192.168.5.0/24 192.168.5.254 LAN 0
I also have a NAT rule fot machines behind MK that look like this:
[admin@MikroTik] > /ip firewall nat print
0 chain=srcnat action=masquerade out-interface=ETB
1 I chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=UNE
2 ;;; NAT TO VPN
chain=srcnat action=masquerade out-interface=pptp-out1
When I enable route number 10 I can ping from mikrotik terminal to IPs behind the VPN what doesn’t happen when I turn it off.
I’m just network student so I’m no expert on routing issues, so any help or correction to what I’m doing here will be greatly appreciated.
You need to have an accept rule at the top of your mangle PCC rules for LAN to LAN traffic. Right now my guess is that your traffic is running through the PCC and going out the wrong route.
Thank you for taking the time to answer; I found a useful page on hidemyass.com (http://wiki.hidemyass.com/Mikrotik_Router_PPTP_and_L2TP_Setup) although it cleared some of black holes I had configuring it and following routing form my LAN could ping and connect to services on the VPN network now this morning I tried it didn’t work, just like that
According to that wiki I had to add a Route, a Mangle Rule and NAT Rule, I have them like this:
Addresses:
[admin@MikroTik] > /ip address print
# ADDRESS NETWORK INTERFACE
0 192.168.5.254/24 192.168.5.0 LAN
1 192.168.0.254/24 192.168.0.0 ETB
2 192.168.169.254/24 192.168.169.0 UNE
3 D 10.10.10.209/32 10.10.10.200 pptp-out1
Routes
1 A S 0.0.0.0/0 192.168.169.1 1
2 A S ;;; HTTP
3 A S ;;; SSL
4 A S ;;; SMTP
5 A S ;;; IMAP
6 X S ;;; P2P
7 X S ;;; UnKNWON
UNE
10 A S ;;; MUNDO VPN
11 ADC 10.10.10.200/32 10.10.10.209 pptp-out1 0
14 ADC 192.168.169.0/24 192.168.169.254 UNE 0
1 chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=UNE
2 ;;; NAT TO MUNDO VPN
chain=srcnat action=masquerade out-interface=pptp-out1 connection-limit=100,32 limit=1,5
connection-type=pptp
I don’t really know how to diagnose this as I now can’t ping from any internal machine to any host on the 10.10.10.0/24 network except fropm Mikrotik itself.
I might have something there on my configuration that’s wrong, now I’m new to mikrotik way of doing things I know some Linux and Cisco but the Mikrotik has my head spinning. I know this would be an advanced topic for a n00b like me but Mikrotik as I said on another post is the only solution I’ve gotten to work with my two WANs in tandem, eventhough SSL continues to be broken but tha’s topic for another day.
