Newbie simple script does apparently nothing
Hello
I am a newbie writing a very simple script to enable/disable the rules redirecting outgoing http traffic to the proxy listening on port 8081. I coded
/ip firewall nat disable [/ip firewall nat find to-ports=8081]
but this does apparently nothing.
I probably have overseen something, but I can’t figure out what. Any help would be very appreciated.
Thanks in advance.
Pierre
/ip firewall nat disable [/ip firewall nat find to-ports="8081"]
Thank you, 2frogs, this works!
It’s really strange that there is no error generated when a script contains a syntax error…
