I just got our Groove G-52HPacn and when I first connected through IP 192.168.88.1 I got straight to the configuration page on Firefox.
Then I got out of the page and since then I have not been able to get to the configuration again. WiNBOX shows the MAC address of the Groove with an IP address of 0.0.0.0 but I cannot connect. There is also no reply if I put 0.0.0.0 in Firefox.
I tried resetting but that has no effect
I’m trying to set up our Groove to pick up WIFI signals on our boat.
Go to System->Reset Configuration and reset the Groove. Don’t select any of the options. This should take you back to to the 192.168.88.1 IP for the Groove. If the IP remains 0.0.0.0 in the Groove then you may need to try loading firmware using Mikrotik’s Netinstall utility.
my suggestions
-open winbox click neighbours tab and see if u find it there.
-try to write manually the mac address of groove to winbox and click connect
-try with another computer
-make sure you reset it correct and try again
Firewall problems, no access through IP, no access through MAC address.. And suddenly we’re back in because I shared the wifi connection. Then the Groove was assigned an IP 192.137… and I managed to get in through WINBOX.
Back to normal now and have access through Firefox.
I’m very disappointed regarding the range though… We have a 15dbi antenna but I can only pick up networks within 1 km (0.7 miles)…
