Newbie with RB750Gr3
Hello guys,
a few days ago I purchased an RV750Gr3 unit in order to start «playing and learning».
The following schematic shows what I am planning to do (for starters).
The red units (Unit A1, Unit A2, Unit B1, Unit B2) can be controlled via a TCP socket at port 9990. The first step would be to set up the IP addresses of the two sides of the mikrotik unit.
I suppose this is how I should do it.
In the first schematic the computer is connected to port 4. I suppose there would be no difference If I connect it to port2 or port3 or port 5. Am I correct?
/export hide-sensitive file=yourconfigmar17
It looks like you have two subnets on the go.
Should the subnets have access to each other?
Is the switch managed or unmanaged?
The switch is a cheap unit, I suppose it’s unmanaged.
The objective is to access the four red units (A1, B1, A2, B2) from the computer. Anything else is not needed therefore it should not be allowed.
