Hi there. I am doing some voluntary work for a community centre. I am not skilled with networking so please be patient and explain technical terms! Thank you.
There is a Unifi 8 port switch running 3 APs and a Raspberry Pi/digital sign.
I am trying to add VLAN tagging, but the ISP's Huwaei router is poor, and cannot create separate DHCP ranges.
So my intention is to insert a Mikrotik RB750r2 between the ISP's router and the Unifi Switch to create the DHCP ranges.
I was lucky to get some great help from a mailing list of IT support teachers. They felt the best way to do this was set up IP pools and addresses, then connect the IP pools to DHCP ranges tied specific ports on the Mikrotik. I can then patch the three ports to the Unifi Switch and set up tagging and VLANs on the switch itself. They advised to check that if the laptop is connected directly to the assigned LAN ports on the Microtik, an IP in the relevant range for that port is offered by the DHCP server.
However, I keep getting these annoying messages about "slaves". It will only let me create one DHCP server on the bridge, so I can't attach the IP pools to specific ports. I can get a dhcp address but it's from the one pool I was able to attach to the bridge no matter which of the LAN ports I plug my laptop to. It won't allow me attach a DHCP server to any of the three LAN ports that I want to (ether3,4,5) because they are "slaves". I have set up DHCP addresses for the three pools. The bridge setting shows the WAN and LANs are attached to the bridge but there doesn't seem to be an option to disconnect them.
What should I try? I have watched lots of videos and read lots of forum posts but I'm stumped.
I attach the exported config file. Thanks in advance for any help you can give! If you need other bits of information eg screenshots, just let me know.
Best wishes
Imogen
apr/02/2018 20:23:28 by RouterOS 6.41.3
software id = FI2A-4PNC
model = RouterBOARD 750 r2
serial number = 67D207818658
add admin-mac=64:D1:54:51:20:DA auto-mac=no comment=
"created from master port" name=bridge1 protocol-mode=none
set [ find default-name=ether2 ] name=ether2-master
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=192.168.8.2-192.168.8.254
add name=TACC10-alternative ranges=192.168.10.100-192.168.10.200
add name=TACC20-alternative ranges=192.168.20.100-192.168.20.200
add name=TACC30-alternative ranges=192.168.30.100-192.168.30.200
add name=TACC10 next-pool=TACC10-alternative ranges=
192.168.10.10-192.168.10.15,192.168.10.20-192.168.10.25
add name=TACC20 next-pool=TACC20-alternative ranges=
92.168.20.10-192.168.20.15,192.168.20.20-192.168.20.25
add name=TACC30 next-pool=TACC30-alternative ranges=
192.168.30.10-192.168.30.15,192.168.30.20-192.168.30.25
add address-pool=TACC10 authoritative=after-2sec-delay disabled=no interface=
bridge1 name=dhcp-TACC10
add bridge=bridge1 interface=ether2-master
set discover-interface-list=discover
add interface=bridge1 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=bridge1 list=mactel
add interface=bridge1 list=mac-winbox
add address=192.168.88.1/24 comment=defconf interface=bridge1 network=
192.168.88.0
add address=192.168.10.1/24 interface=ether2-master network=192.168.10.0
add address=192.168.20.1/24 interface=ether3 network=192.168.20.0
add address=192.168.30.1/24 interface=ether4 network=192.168.30.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=
ether1
add address=192.168.8.0/24 gateway=192.168.8.1
add address=192.168.10.0/24 dns-server=89.19.64.164,89.19.64.36 gateway=
192.168.10.1 netmask=24 ntp-server=192.168.10.1
add address=192.168.20.0/24 dns-server=89.19.64.164,89.19.64.36 gateway=
192.168.20.1 netmask=24 ntp-server=192.168.20.1
add address=192.168.30.0/24 dns-server=89.19.64.164,89.19.64.36 gateway=
192.168.30.1 netmask=24 ntp-server=192.168.30.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="defconf: accept established,related"
add action=drop chain=input comment="defconf: drop all from WAN"
in-interface=ether1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=accept chain=forward comment="defconf: accept established,related"
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade"
out-interface=ether1
/system clock
set time-zone-name=Europe/Dublin
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
