newby questions
Hi I am the proud new owner of RB750 and a few questions
1 the thing comes with routerOS do I have to register this or something or is it good to go ?
2 this board has only ethernet ports no console or serial how easy will it be to lock myself out? (given i will be ssh and CLI)
3 having done that will i be able to restore somehow
4 Can i prepare for such an event by saving my software key (how see Q1) or saving my firmware or some other means
thanks
:confused:
  1. Good to go
  2. That’s why you have five ports :slight_smile: If you disable one, you still have others.
  3. If you disable all - you have the reset button
  4. You don’t need to save the key, but you can safe software configuration in a file with the command “/export file=name” and “/system backup save”. Do both, as each file has it’s own advantages.
thanks for that but i cant for the life of me see where the dratted karma buttons are :confused:
nope the + and - tick boxes are not present for me
on a more serious note i cant seem to find a CLI guide lots about API and winbox is there a CLI reference?
ahh ha your karma buttons have magically appeared but not for normis
I didn’t really deserve karma for that…
http://wiki.mikrotik.com/wiki/Category:Manual <— manual, which also contains CLI commands
  1. I can’t receive Karma
  2. Karma buttons are only for people with more than 5 posts (I think)
