Newer BandRich modems? Which ones?
*) support BandRich modems with newer firmware;
I’m wondering if anyone has tested any newer BandRich modems (particularly USB and LTE) and what their results were.
Very excited about this feature.
It is the same C501 modem just with a newer firmware as when you upgrade the modems firmware and plug it in the router it wasn’t recognized. Now with the new RouterOS version it should be recognized and working ok.
Thank you.
Do you happen to know if the BandRich USB modems are compatible with the Verizon (or any other US carrier) LTE network?
If not, are there currently any supported USB LTE modems that work with American carriers?
Thank you again.
