My 10+ year old SXT Lite2 died so I replaced it with the newer SXTsq Lite2. Anyone else find the design rubbish?
The cutout hole for the cable is far too small for any proper outdoor rated cable.
The mount is also non-existent. Using a hose clamp isn’t a mount, you can’t get them tight enough to a pole nor adjust azimuth.
The old design wasn’t perfect either, but the newer one doesn’t appear to have had any thought other than “looking cool”.
