Newly created GRE tunnel is not running
I have a problem which is the newly created GRE tunnel is not in R state. The state column is empty.
MT1 ==> /interface/gre/add remote-address=2.2.2.2
MT1 ==> /ip/address/add address=10.10.74.1/30 interface=gre-tunnel1 network=10.10.74.0
MT2 ==> /interface/gre/add remote-address=1.1.1.1
MT2 ==> /ip/address/add address=10.10.74.2/30 interface=gre-tunnel1 network=10.10.74.0
And I see the following routes are created automatically in both MTs:
[admin@MikroTik] > /ip/route/print
Flags: D - DYNAMIC; I, A - ACTIVE; c, s, y - COPY; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, DISTANCE
#      DST-ADDRESS      GATEWAY       DISTANCE
  DIcH 10.10.74.0/30    gre-tunnel1          0
Would you please help me where’s the issue? I googled and some websites told to add static route manually, but it’s done automatically.
In ROS 6, there used to be a firewall issue with GRE, and in ROS 7, there used to be some issues with the keepalive. As the first step, post the export of your configuration.
Thanks, it’s ROS7.
This is the full configuration:
[admin@MikroTik] > export
# aug/16/2024 08:08:14 by RouterOS 7.6
# software id =
set [ find default-name=ether1 ] disable-running-check=no
/interface gre
add name=gre-tunnel1 remote-address=home_ip
/interface 6to4
add !keepalive name=6to4-tunnel1 remote-address=office_ip
add !keepalive name=6to4-tunnel2 remote-address=home_ip
/interface wireguard
add listen-port=14035 mtu=1420 name=wireguard1
/port
set 0 name=serial0
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=office_ip endpoint-port=14373 interface=wireguard1 public-key="Vbhh6WAfz0yrU29Tn6qsmKRSXj45AYPLLXu9UXzbBCU="
add allowed-address=0.0.0.0/0 endpoint-address=home_ip endpoint-port=14035 interface=wireguard1 public-key="OJgnIiM1ZZkqwUChBH4VtntlBo9FnMcAZLmuGto0iAY="
add address=server_ip interface=ether1 network=server_gateway
add address=10.10.73.1/28 interface=wireguard1 network=10.10.73.0
add address=10.10.74.1/28 interface=gre-tunnel1 network=10.10.74.0
add address=10.10.75.1/24 interface=6to4-tunnel2 network=10.10.75.0
/ip dhcp-client
add interface=ether1
set servers=8.8.8.8
add dst-address=0.0.0.0/0 gateway=server_gateway
/ipv6 route
add disabled=no dst-address=::/128 gateway=ether1 routing-table=main
/ipv6 address
add address=fc00::1 advertise=no interface=6to4-tunnel2
/ipv6 firewall nat
  • the firewall is not the reason why GRE does not work as it is basically nonexistent on this router (NAT doesn’t filter incoming traffic, so your internal addresses are still reachable via the WAN, and if they are global, the IPv6 ones are reachable from anywhere)
  • the ROS version is 7.6 so it may be the reason
  • as you deemed it necessary to substitute the remote-address, I suppose it is a public one, which opens a new can of worms:
  • some ISPs do not let GRE through
    • most NATs have problems to handle GRE
So what is the overall topology, does this router have a public IP directly on itself or it is behind another NAT? Same question for the one at home.
Thanks, I disabled the keepalive and the GRE tunnel is now running.
I can ping both private IPs from both home and the server (office is not important now).
My home internet is behind the NAT and I don’t have a static IP. I think if required, I can request to obtain a static one.
I tried running a Wireguard between home and server. It works. I created a new WiFi interface to route all traffic via the interface and that interface routes all traffic via WG interface.
The above line works and when I connect my mobile to new WiFi (let’s call it home-bridge) and I google my ip, it says it is WG’s IP.
If I connect to my default home WiFi (it’s home-repeater) and I google my IP, it says my ISP’s IP.
Now when I disable WG, then enable WG, then change the route from WG to GRE, my mobile does not have any internet access. But as soon as I change route to WG, I have internet access.
This is my home configuration:
# aug/16/2024 12:34:38 by RouterOS 7.8
# software id =
# model =
# serial number =
add admin-mac=78:9A:18:2C:9E:D2 auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz configuration.mode=ap .ssid=home-repeater2g \
    disabled=no name="wifi 2g" security.authentication-types=wpa-psk,wpa2-psk
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=home-repeater5g \
    disabled=no name="wifi 5g" security.authentication-types=wpa-psk,wpa2-psk
add configuration.mode=ap .ssid=saeed-bridge disabled=no mac-address=\
    7A:9A:18:2C:9E:D6 master-interface="wifi 5g" name=wifi1 \
    security.authentication-types=""
/interface gre
add !keepalive mtu=1492 name=gre-tunnel1 remote-address=server1_ip
/interface 6to4
add disabled=yes !keepalive name=6to4-tunnel1 remote-address=server2_ip
/interface vlan
add disabled=yes interface=ether1 mtu=1492 name=vlan1 vlan-id=801
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment="wireless interfaces" name=wireless
add name=dhcp_pool3 ranges=192.168.73.2-192.168.73.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=dhcp_pool3 interface=wifi1 name=dhcp1
/routing table
add disabled=no fib name=vpn
add bridge=bridge comment=defconf interface="wifi 5g"
add bridge=bridge comment=defconf interface="wifi 2g"
/interface detect-internet
set detect-interface-list=all
add interface="wifi 2g" list=wireless
add interface="wifi 5g" list=wireless
    192.168.88.0
add address=10.10.73.3/28 interface=wireguard1 network=10.10.73.0
add address=192.168.73.1/24 interface=wifi1 network=192.168.73.0
add address=10.10.75.3/24 interface=6to4-tunnel1 network=10.10.75.0
add address=10.10.74.3/24 interface=gre-tunnel1 network=10.10.74.0
add address=192.168.73.0/24 gateway=192.168.73.1
    192.168.88.1
set allow-remote-requests=yes cache-max-ttl=1h servers=8.8.8.8
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=vpn passthrough=yes \
    src-address=192.168.73.0/24
    ipsec-policy=out,none
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=wireguard1 pref-src=\
    "" routing-table=vpn scope=30 suppress-hw-offload=no target-scope=10
/ipv6 address
add address=fc00::2 advertise=no interface=6to4-tunnel1
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Asia/Tehran
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set memory-scroll=no
I’m so sorry if that’s a lot and that’s not clean:(
Since you can (apparently, please confirm) ping 10.10.74.1 from 10.10.74.2 and vice versa, that sounds like the issue of early versions of ROS 7 I’ve mentioned. So upgrading both ends to the latest version should allow you to re-enable the keepalive. With keepalive disabled, the tunnel interfaces stay active regardless whether the network path between them is working or not.
The issue with GRE and NAT is that the device that doesn’t have a public address must keep sending some payload packets (or the keepalive must be enabled) so that the NAT would keep the pinhole (tracked connection) open - if that device is silent for minutes, the NAT device will remove the pinhole and drop the GRE packets coming from the server as it will not know where to send them at the private/CGNAT side. Plus there are additional issues with this even if you keep the pinhole alive one way or the other.
GRE tunnel itself is stateless and has no authentication or encryption, so given your environment, think twice before using it for any data.
You have to either change the route at both devices (home & server) or you have to use src-nat at home also for traffic leaving through the GRE tunnel so that the server saw everything as coming from the address assigned to the home end of the tunnel and hence did not need a manually added route.
