Newly installed RB2011 loses its config
Hi
A client recently asked me why RB2011 sometimes lose their config after the initial setup
They apparently lock up and there’s nothing left to do but reboot electrically and start over
Any ideas?
thanks
yann
It’s not supposed to. Maybe it’s defective? Tried another RB2011?
Thanks for your response
I agree, but apparently they have experienced this issue with several RB2011
regards
yann
It’s not normal and it’s not something that should happen over multiple RB’s. I guess normal applies, ensure latest ROS and FW. They may be applying config with safe mode on, losing connection and the board reverting changes.
Thanks Steve, I’ll check this out
I had the case with a customer, same symptoms. After some searches it appeared that the customer had made a configuration template, and then duplicated the config using “backup” and “restore” ! Which is not good for different devices, I told him to use export/import with .rsc files instead and his problems disappeared.
Thanks Noib, will check this out too
