Yes that too, especially if you can make it compatible with existing 6 GHz Cambium ePMP1000 CPEs (difficult to replace them all quickly, but they have “standard WiFi” mode in addition to their proprietary TDMA - which BTW works quite well, even has working GPS sync, but it’s still 802.11n and they haven’t made 6 GHz versions of newer ac/ax product lines). LHG6E would be nice (SXT6 just like Cambium Force180 are only 16 dBi which limits the range for good performance, and more gain needs expensive connectorized radio + expensive separate antenna, very few available for the full 6 GHz band), as well as a good WiFi6E integrated sector base station.
Hi all, are you commenting past your start of the week, well I hope.
I’m a new mikrotik REST API user and I have a little problem…
I would have liked to know if there is a way to get the creation date and time of a hotspot user with the rest api.
Thanks very much.
