wow 32 MB Flash. This cut cost corner doesn’t make sense and they have to come later to do crazy and stupid things to split packages like the mess on the wifi ones just because there is no enough storage nor memory.
40 Gbps is being replaced by the 25 Gbps / 100 Gbps ( Even the CCR21xx series comes with no 40 Gbps ports ) and the Industry is moving away from 40 Gbps.
No PoE+ or PoE++ ports but twice the cost of a CRS328-24P
3X times more expensive than the CRS 326-24G just to add 2.5 Gbps + 2 extra SFP+ ports and 2 x 40 Gbps uplinks doesn’t make much sense to me
-Single core on the CPU not even dual?
There are some nice features but looks a downgrade in other key components like RAM, Storage and CPU
Also, why is it using a mipsbe CPU when MikroTik is clearly moving everything they have to ARM? Even the $60 hAP ax lite has a dual core ARM CPU, but a $1000 switch does not?
Yeah, RAM and CPU are mostly meaningless for a switch, it’s just for management purposes. The big question is if the switch chip is stable or if it has problems like the other CRS models.
Well if you want to use the switch as Layer 2 only, agree with you but if you want to enable advanced features on L3 like Dynamic Routing or any other advanced features, becomes an issue or even worst not a viable option to use.
Again, why nickle and dime on this? The whole idea and mantra of Mikrotik is to do whatever you want but if you are handicapped on this basics, the value of the hardware (Switch on this case) plummet.
I support a CRS312 that has 64 MB with L3 HW Offload. The switch reboots every 2 weeks when Memory gets maxed out.
I also have a CRS326-24G with 512 MB and is a rock solid (not issues compared with the CRS312).
So for me CRS312, CRS5xx series and this new one is Dead on Arrival (Aside of the 3X times price issue for additional port speeds (2.5 Gbps) and couple extra SFP+ and 2 x 40 Gbps that the Industry is abandoning.
So there’s two things here.
On the CRS312, I can say that I’ve had one running for well over a year and the only reboots it’s had are for ROS updates. It’s only doing layer2 and “the snoopings”; routing is disabled and it’s only “reachable” via a management VLAN.
I “feel like” there’s a memory leak causing your reboots, but it’s definitely not in any of the modules/features that I’m actually using. Throwing more RAM at a memory leak is an expensive bandaid… My recommendation would be to monitor RAM use and once you see it getting “rather high”, generate a supout and put in a ticket with it so that their boffins can have a look.
The second thing, I definitely have mixed feelings on the switching/ports.
40Gbe ethernet is the same generation of tech that 10Gbe is… so for shops and use cases that are still “fat, dumb, and happy” with the 10Gbe, then 40Gbe is usually still ideal… because at the end of the day, those 40Gbe uplinks can be broken out to separate 10Gbe connections if more ports are needed, and on top of that (in this specific case) a single one of those 40Gbe uplinks is likely to be enough to keep the bulk of the 2.5Gbe connections happy.
Using a newer asic that has native 25/100Gbe switching, instead of 10/40Gbe switching, would have made this CRS326-4C+20G+2Q+RM even more expensive.
It’s marketed as a Cloud Router Switch. If you use it for its routing functions, CPU performance does matter (even with the addition of L3 HW offloading).
Besides, the use of an ARM CPU allows for features that are not available on other platforms. If I want to use ZeroTier to manage my switches, I could do that on the previous model (CRS326-24G-2S+RM) but not on the new one.
It’s the same story with the CRS328-24P-4S+RM: ARM CPU w/ 512MB of RAM. You want to upgrade your 24 ports PoE switch to an 48 ports switch and buy a CRS354-48P-4S+2Q+RM and suddenly you’re stuck with a MIPS CPU that’s half as fast and you only have 64MB of RAM. Even if it is “fast enough”, MikroTik’s choice of management CPUs just doesn’t make sense.
On the CRS312 could be a memory leak but I see memory running almost full and I see random reboots every 2 weeks. I have similar configurattion on a CRS326 with 512 MB of RAM and have zero issues with random reboots. That tells me that these switches are running too tight on memory specially knowing that these days are very inexpensive, why not normalize the whole production and models with the same memory (i.e., 1 GB) and avoid nickle and dime for optimize RAM or Storage to keep compatibility in future releases? I still don’t get it.
Got your point on the 40 Gbps and fine with that BUT 3X times price increase and not even PoE support makes this switch a DoA for me.
I dont have any information about the reasons for CPU selection in case of CRS326-4C+20G+2Q+RM
but
some months ago industry rumors talked about notable ARM changes in royalty fee policy, some rumors point towards ARM asking not only for a percentage of chip cost as previously was but also now they ask for a percentage of the total retail price of the product contaning an ARM chip
that can be a hefty reason to avoid to use ARM whenever possible
For a switch the CPU is mostly used for management purposes, this device is mainly focused towards pushing traffic using hardware offload features of switching ASIC, so the kind of included CPU is not a game changer
Unfortunally I’m afraid that some part of Mikrotik is going all in for the “performance-per-$” race, that can never be won because of China/Aliexpress/etc. That’s why we see a lot for CSS-models.
In my opinion it’s better to focus on real professional features (like advanced-switching, routing-protocols, encryption, API:s), unique hardware features (size, fanless, DC-fed) and affordability. People that want’s the cheapest possible 2.5G/10G switch will head to Aliexpress.
As far as I can tell they use the same CPU (QCA9531) on their top of the line CRS5xx 100Gbps switches, and on a side note it was also used on a tiny mAP and hAP devices because it is actually wireless IEEE 802.11n SOC so maybe Mikrotik has huge number left of those because low cost AP sales wasn’t going so well :)…
On the other hand it is probably good enough for just a management tasks as it should be the case, but I would much prefer PoE model since we already have RB5009 and ax3 with 2.5G PoE in ports and any 5 GHz ax wifi device already needs something faster than 1G… and they could skip QSFP+ ports to keep the price reasonable…
You have to remember the ARM CPU in the other switches is integrated in the switch chip itself. If it’s not an option with the switch chip they’ve chosen for a particular product, then it’s additional cost just to improve routing functionality.
To anyone in North America, neither the new wAP or '24 LtAP will work there.
Now the new Fiber adapter – that is a good concept.
Well said. I’ve never understood the market for their switches – nothing has good PoE support so always been a “game ender” for me & RouterOS interface for line-rate L2 switching is kinda lousy and error-prone. I guess the pricing meets some market need, dunno.
I just keep hoping they expand out the RB5xxx in creative directions. The ability to mix-and-match various RB5xxx to form a “stack” covers a LOT of use cases. It’s just sad that half-rack Netgear M4300 series is a better fit with RB5009 than anything from Mikrotik switching — more $ but 10G ports & different port configs in same FF.
As @mada3k points out, there are a lot of generic switches out there if cost is number one concern. Having one vendor for routing and switch & good interop/management would nice, but NONE of the switches have ever meet any real-world need of mine. And if I have many switches to manage, the Mikrotik option to manage them is The Dude?
Sorry for rant… but between word “gamechanger” for 2.5G switch without PoE & another IoT diagram using device without BTH/zerotier support – all a bridge too far
It’s also very strange to have both fans and a big passive radiator. It’s neither forced-air cooled nor passive-cooled. It must be quite expensive to manufacture all that heatsink for nothing.
Forced air devices have the advantage of be able to operate in warmer areas, passive ones can not.
Perhaps the initial idea was to make device passively cooled but later it turned out it wasn’t enough so they installed some fans. And somebody forgot to cancel the order of half a million of heat sinks?
Forced air and passive-cooling are actually pretty commonly used together (for example fans and heat sinks on CPUs) so is it is not OR situation…
But in this particular case 2 fans are used mostly for pulling air from PSUs to cool those 2 down and also improve SFPs cooling, switch chip is cooled by the large heatsink with pipes, actually there is an empty space and connector for additional fan that you can connect and use to improve air flow along heat sink if switch is used in wormer areas although that would probably void the warranty…
