5 pages this time!
http://download2.mikrotik.com/news-42.pdf
Cloud Core Router pricing
RB2011 new models
Academy news
MUM news and videos
Hidden feature - cable problems
RouterOS v6
5 pages this time!
RB2011 new models
Academy news
MUM news and videos
RouterOS v6
Hidden features: cable problems. Should this work on the RB750UP? Not seeing anything different here.
Do you have RouterOS v5.21 and latest RouterBOOT (check routerboard upgrade menu). I can see it on mine
Yup. 5.21 and 3.0 firmware
post output of command “/interface ethernet monitor [find]”
[admin@MikroTik] > /interface ethernet monitor [find]
status: link-ok link-ok no-link link-ok no-link
auto-negotiation: done done done done done
rate: 100Mbps 10Mbps 10Mbps 100Mbps 10Mbps
full-duplex: yes no no yes no
– [Q quit|D dump|C-z pause]
We tested with v6rc3, we will have to fix the manual. Some devices were added in v5, some only in v6
Better fix the newsletter as well ![]()
So which devices do work in 5.21?
2011 with 5.21 and 3.0 works also no.
regards
Christian
so far it looks like driver is in v5.21, but console doesn’t show relevant info.
only RouterOS v6 supports the cable diagnostic at this point
And 5.22 will support Cable test?
I believe it’s not working at all on RB750GL. I tried on 5.21, then upgraded to the 6.0RC:
[admin@WestRidgeSwitch1] /interface ethernet> /sys resource print
uptime: 16m15s
version: 6.0rc3
free-memory: 50348KiB
total-memory: 61876KiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 400MHz
cpu-load: 2%
free-hdd-space: 51208KiB
total-hdd-space: 61440KiB
write-sect-since-reboot: 1120
write-sect-total: 359903
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB750GL
platform: MikroTik
[admin@WestRidgeSwitch1] /interface ethernet> /system routerboard print
routerboard: yes
model: 750GL
serial-number: 3B06020B2008
current-firmware: 3.0
upgrade-firmware: 3.0
[admin@WestRidgeSwitch1] /interface ethernet> monitor [find]
status: no-link no-link no-link no-link link-ok
rate: 100Mbps
full-duplex: yes
750GL, 750, SXT G, 711G, 2011 will be added in v6rc4
Sweet.
Most of the links do not work. For example, on the last page.
Łukasz,
thank you very much for the report.
We will fix links in the newsletter.
this is normal for portable devices like phones and tablets. it works fine on a PC using Acrobat reader
I tried on PC with win xp sp2 and acrobat reader 10.1.4.38.
Link on first page work without issue. Links on last page does not work.
No luck with cable monitoring in RC4 on RB750GL.
… But it does work on the RB2011L FastE ports.
