- SXT Lite5
- RB951G
- MikroTik awarded
- MUM in Europe
- Partitioning
- New CCR video
Do you need to have two ROS licenses in order to use two ROS instances on one routerboard with two partitions? In other words, does each partition require a separate ROS license? Thanks.
no, you don’t. License is bound to hardware, and you don’t change hardware
by the way, you don’t need additional licenses for Metarouter RouterOS instances
Will netinstall discover two partitions in the routerboard or how to install ROS on the second partition?
Congratulations on the Leading Exporter award ![]()
Netinstall will reinstall only the currently active partition. To delete the partitions, you must do it either from within RouterOS, or within the RouterBOOT setup menu.
Thanks, that helps a lot.
Can partitioning function be used on x86 platform? I don’t see it in the menu options (6.0rc11)
