Dear my Friend
When the next version of MT (3.21) Release ???
I need the web-proxy package with HTTPS support in transparent mode.
thanks
Dear my Friend
thanks
Guys can we have a reply at least if its going to be this month or the next???
The BGP module on the 3.20 is not usable.
Are you sure 3.21 will allow HTTPS in transparent mode? I didn’t think it was possible to transparently proxy HTTPS.
What I know it fixes is to use it as a normal proxy but redirecting to a PARENT proxy with HTTPS.
