NGF transparent mode with Mikrotik
We have been using Mikrotik at our datacenter for a while and are quite happy with it but it lacks in the next gen firewall features but so we do not want to go through changing mikrotik to a paloalto/sonicwall/sophos. However we would like to take advantage of the packet inspection and logs that these devices offer. They all have transparent modes where you can drop in the device between mikrotik and switch so they will monitor all the traffic. Has anyone used something like this? Will appreciate if you can share your experience or if you have any other suggestions.
Thanks in advance!
For IDS is standard best practice to place the IDS devices off-path, i.e., use Switch > Rule to mirror your WAN traffic to another port, then feed this mirrored port to IDS device.
