Nginx:latest: download/extract error: check registry failed: SSL: ssl: no trusted CA certificate found (6)
Hi Mikrotik Team,
on ROS7.20 and ROS7.21rc1 i’m not able to fetch an container image.
/container/config/set registry-url=https://registry-1.docker.io
/container/add remote-image=nginx:latest interface=veth1
Flags: F - DOWNLOAD/EXTRACT FAILED
Columns: NAME, ROOT-DIR, INTERFACE, CPU-USAGE
#   NAME          ROOT-DIR      INTERFACE  CPU-USAGE
;;; download/extract error: check registry failed: SSL: ssl: no trusted CA certificate found (6)
0 F nginx:latest  nginx:latest  veth1              0
i’ve tried to import the CA from docker which is Amazon - but no change here.
Is there an Workaround?
Best Regards!
Is it too obvious to install the certificate it doesn't find?
I'm probably wrong, thinking such a trivial thing while reading the error,
maybe something else needs to be done... like set the right date and time in the clock...
In this case with registry-1.docker.io you only need to change this setting:
  • In 7.21rc1:
    /certificate settings set builtin-trust-store=all
  • In 7.20.6:
    /certificate settings set builtin-trust-anchors=trusted
And @rextended is correct, you should also make sure the clock is properly synchronized.
