Good day,
I’ve decided to give RouterOS a try and I’m very impressed, just having a small problem with my NICs.
I have ROS installed on an Intel x86 system and its running great, I’m using 4 NICs, one being the on-board NIC and the other three PCI NICs.
The on board NIC (Intel PRO/100) serves as the WAN interface, a PCI NIC (RealTek 8139) serves as the LAN interface, and another PCI NIC needs to serve as the WIFI interface.
Problem is, I cannot get the other two working. One is a RealTek RTL8139D which, according to the hardware list, is supported. This NIC just does not load up. I can see it under System> Resources> PCI, but not under Interfaces.
The other is a Davicom DM9x0x. This NIC does load up, I can see the driver and I can see it under interfaces, but it does not work, if I check under status it tells me Auto negotiation: incomplete; Rate: unknown
I hope someone can help. Thanks in advance.
