Hi, does RouterOS support Realtek RTL8110SC nics? They aren’t listed on the compatibility list (although that may be out dated?)
Also the Intel 82541PI nics are listed as having issues with higher speeds, is this still the case?
Cheers
Cheers
i have not had much issues with any nic’s not being supported in RBPC’s or so forth, cant say much for the performance thou.
