I’m having problems getting Mikrotik 2.8.12 running in AP mode on the Senao Atheros Cards model NL-3054MPA. I have 2 units and they one will only see the other if in B mode but not in G mode. I have a notebook with netstumbler that sees the AP in G mode fine, just not the mikrotik client. Any ideas what could be going on here or is it a compatilibity issue with the senao cards and mikrotik?
Check your configuration, maybe you have misconfigured it. I suggest to do ‘system reset’ and configure just like in my configuration.
Also check if you have antennas connected to the cards.
Well that got me working, well kind of. Turns out that the ufl pigtail had come off the card and I had the antenna’s assembled. Got that taken care of and now its working like a champ. Thanks for your help.
